Face Mocap for Gen 9
DekeDeke Posts: 1,636
Will Face Mocap work on a Gen 9 figure? There are G3 and G8 Mocap products and not sure if they will translate.
  • GordigGordig Posts: 10,822
    I would imagine that you'd need a mocap that will work on G8.1, since 8.1 and 9 have the same facial rigging (or, at least, more similar than either is to G3 or G8).
  • DekeDeke Posts: 1,636
    Thanks. I'll give that a try.
  • I have FaceMotion for G8 and 8.1, which is essentially the same product, and it doesn't work on G9. I'm guessing it's because the shape keys aren't set up for G9. You might be able to send it to Blender via diffeo, set up the FACS on the rig and then import the FaceCap .txt file. It might work but I haven't played around with it since I'm not using G9.
    Thanks. You saved me a bunch of grief.
