Can't re-install or use DAZ, What directories are these?
jpetersen1
Can someone tell me which "Package Archive" in which "Downloads" page of which "Settings" dialog this is supposed to be? It's as clear as mud.
Also, when I click OK, whether in DIM install or Central install, this popup goes into an endless loop and I have to Kill the process.
I was using DazStudio fine until a few months ago and now it doesn't work. Can't reinstall, I keep getting this message in the attached screen shot.
Suggestions appreciated.
700 x 349 - 236K
It's saying it can't find the folder in which it is told to place the downloaded zips (and, for Daz Central, delete them once the installation is done. The drive may be full or the location set for the zips may be inaccessible, for example a disconnected drive or drive identifier changed.
If you're using more than 1 external drive, remember to attach them in the correct order so the Letter associations are the same.
