Making holes in walls?
I just tried to make a hole in a "wallpaper" planewith an Iray decal node, I made a cutout opacity mask for the hole that I wanted and the shape of the hole is spot on, only problem is that the hole isn't see thruogh, it's filled out with the default color, what can I do to make the hole see through? or are there any other ways of making a hole in a wallpaper in Daz?
https://imgur.com/a/WDFQZ1p
Thanks for the help.
  • felisfelis Posts: 6,504
    A decal functions as a projected overlay.
    If you wan't a hole in the wall, you need to make the hole using the cut.out oppacity for the wall
    edited December 2022
    There is usually more than one way to do something.  Instead of a decal node, place the hole that you want in the cutout opacity channel.  Here is an example of a plane with a wood texture placed in the 1000 in 1 nights set.  In an image editor, I made a square hole and a circular hole.  I placed my hole image in the opacity map.  If you want to place the hole in a specific place on an item that is not square, you may want the UVMap of the item.  Or just do trial and error.
    512 x 512 - 21K
    1712 x 1003 - 440K
    1723 x 1012 - 374K
    1429 x 2000 - 5M
    Post edited by Diomede on
