Can I create duplicate panels?
I want two parameter tabs.  Is it possible?    Maybe I could have one parameter tab for the deformer field settings, and one parameter tab for the deformer itself.  It's a pain to switch back and forth.
  • fixmypcmikefixmypcmike Posts: 19,733
    I don't think so, because you would need to select 2 items at once and have each panel know which one is selected.  I don't use the "Rooms/Activity Tabs" -- can you have a different item selected in different rooms and flip back and forth?
  • Uncheck Consolidate Properties in the Parameters pane option menu (the lined button in the top corner, or right-click the tab). That will allow you to see the parameters for two selected items separately, though they are not labelled - they are however listed in selection order, newest at the top and oldest at the bottom.
