3D Bridge
Some help please,
I'm getting an error installing Photpshop and it's not in the applications tab.
I've searched the forum using the words...photoshop, failed, no path and 3D bridge,  and can't seem to find anything on this subject.
thanks
587 x 544 - 24K
571 x 536 - 46K
555 x 524 - 61K
  • FishtalesFishtales Posts: 6,245
    You have to add the path to where Photoshop is on your hard drive so that DIM and Bridge know where it is so it can be launched when required. In your last image, bottom left hand corner, click on the + sign and then navigate to the folder where the Photoshop .exe file is, select it and save.
  • Make sure you also tell it that the path is for Photoshop, and the version.
    681 x 690 - 102K
  • Joseph_TJoseph_T Posts: 43
    Thank you, thank you, thank you......
