how to edit this?
sorry i dont know what this is called. i need to change this so that the toes bend in the proper manner for this kind of leg. i need the whole toe section to be farther back where the red line is?? the base is the genesis 9 model. thanks
  • felisfelis Posts: 6,645
    I am in doubt if you are talking bending or morphing.
    If you are talking about bending, you can click on the mesh to see if there is an area that you can bend to get what you want. Activating the joint editor will show which bones there are.
    If you are talking morphing, i.e. moving the mesh, it requires that there either exist a morph supporting what you want, or you must take the model into a modeller and adjust it to your liking, and then create a morph based on that.
