Need help with new error message showing up
All of a sudden daz is coming up with this message when loading genesis 8 male:
/data/ziadhoops/Product/2/Genesis8Male.dsf
Never seen it before and no idea where it came from   Anyon else ever see this and know how to fix it?
  • Where is this appearing? Is there any more to the message?
  • I also have same issue when trying to load a scene or create new figure. This start happen when I installed many things. Don't know which one cause the issue. Any idea how to fix this?
    510 x 454 - 20K
  • He's not listed as a PA, maybe from some freeware or item sold elsewhere?
    He is a member of these forums though so maybe @ziadhoops  will get his attention for some enlightening information.
  • It looks like a bad reference, possibly it is emant to be the base figure and should be pointing to that or it may be pointing to a modified version, which could not be distributed.
    I see, if that the case how do I fix that?
  • Check the log file (Help>Troubleshooting>View Log File) after loading and getting the error - if you scroll back from the end you may find the error, adn it may tell you exactly which file has the bad reference.
  • BejaymacBejaymac Posts: 2,014
    Sounds like bad "Parent" data, so you will find three warnings in the log, unfortunately those warnings only show the asset ID, so you wont get the file location from the log.
    My log file as per attachment. I don't understand anything or what to do. I'm still new in Daz 3D. Hope you guys can guide me.
    I also don't see any visible weirdness on my character either just it keeps pop up every time I load a scene which is annoying. I wonder if I can remove the pop up error permanently.
    txt
    txt
    log missing file.txt
    1M
  •  I had the same problem,  and I found the offending morph. You need to go to where your library is installed. Find the data folder, and follow this address: data\Daz 3D\Genesis 8\Male\Morphs\DAZ 3D\Body and then delete the DSF file called aaaa. It's fixed the error message for me.
    Thank you so much! It's works. No more annoying pop up. yes
