Can't find V4 basic morphs
Hi all,
It seems noob question, but still I can not figure it out. So please, help.
Problem is do not see Victoria viseme (and some other) morphs in shaping pane. I have correctly installed V4.2 with powerloader. I am trying to load base figure with base morphs - visemes and some other. It loads, shows no errors and... only two damned morphs I see in shaping pane are MaleBody and MaleBodyNoScale!
On the other hang, when I load genesis figure everything works fine - I can see all morps. So am I doing something wrong, or there is another reason?
Thanks.
Post edited by Makumba666 on
They are in the Parameters tab, under the Head (select head and they should show up).
This is my parameters tab, with 2 morphs:
And this is what was selected in powerloader:
Can not imagine what can be the reason.
You will find what you are looking for in the Parameters pane with the V4 'Head' selected.
It is under 'Morphs|Expressions'.
Select her head...they are 'context sensetive'.
And here's what it should look like with the head selected...drop down box, univerisal tool, scene tab...doesn't matter how, just that the head itself is selected.
mjc1016,
Now I see my error. Simple. :)
Thank you very much.
