Help me
help me ???
Help
  • D.RobinsonD.Robinson Posts: 283
    I have had this happen to me several times best advice i can give is close the installer and reopen and try again sometimes the sync on the DIM and Daz studio server causes this issue. Also make sure your firewall isnt blocking the DIM
  • fixmypcmikefixmypcmike Posts: 19,743
    I was getting a lot of failed downloads last night, they all worked on the second try.
  • still same :/
    Go to Settings > Show log file, delete the contents of the log file and save, then try the install again, and post the log.
    If all else fails, there's always the option of manually downloading the installer from your Product Library page. I'm not sure how DIM would handle the next time you need an update, though.
  • frank0314frank0314 Posts: 15,117
    Do you happen to have DAZ Studio open while trying to do the update?
  • ı download manually,but freeze program [I don't speak eng] help me please ://
    What security software do you use?
  • Avira but it's closed
    Did you install "PostgreSQL CMS"?
  • PostgreSQL CMS : download link please ?
  • I install but still same
    Do you have the Avira Antivirus or Avira Suite?
  • have avira antivirus
  • Fixmypcmike help me :/
  • Subtropic PixelSubtropic Pixel Posts: 2,403
    edited August 2015
    This is an install failure, not a download failure.
    Check the target partition where you want to install DAZ Studio.  In DIM, that can be found in the settings via the little "gear" icon at the top right of the DIM window.
    If that partition (drive letter, etcetera) does not exist, the install will fail.  If it does not have enough free space, the install will fail.  If you do not have authority to it (standard user, administrator protected the partition or folder, etc), then the install will fail.
    Post edited by Subtropic Pixel on
