Destroyed / ruined Bridges and Steel Constructions
cosmo71cosmo71 Posts: 3,609
Hello,
I know that there are two destroyed / ruined bridges here at the shop, but except of "under the bridge" that comes near two what I am looking for I haven`t found more, have someone a clue where one can get some destroyed bridges or steel constructions? In the set "end of the line" there is a ruined steel construction but unfortunatelly it is not a single item and hiding the other surfaces also not work because the surface of the steel construction is combined with some other surfaces of this set :( so, anyone a clue?
  • cosmo71cosmo71 Posts: 3,609
    edited August 2015
    Hello,
    I know that there are two destroyed ruined bridges at the shop, but these (except "under the bridge" that comes nearly to what I am looking for) are not exactly what I need. What about some destroyed/ruined bridge props? In the product "end of the line" there is a ruined steel construction that comes near to what I need but unfortunatelly this is not a single item and hiding the other textures via the surface tab is not possible because the texture is also not a single surface. So some ruined/destroyed steel bridges and constructions would be great. I need them for close ups and also as backrounds in the distance. Maybe a version with a road on top and another version just as steel/brick or just steel construction.
    Or, what be also helpfull a set of different steel/iron probs like different steel bows maybe weith truss, steel beams, steel truss probs, steel/brick columns, road probs, so one is able to create its own destroyed/ruined constructions. A destroyed/ruined steel construction set with different textures.
    Post edited by cosmo71 on
    Threads merged.
  • scathascatha Posts: 756
    I think sparky had a set like the one you're looking for over at vanishingpoint.
  • In the City: Destroyed Bridge is quite good. I have it and it's a big set. As for rubble, RuntimeDNA has a free rubble set. Just look under "zero price items".
    thank you I know this set and looks good but it is not what I am looking for, I am more looking for old ruined / destroyed iron/brick constructions/bridges with steel truss constructions and or bridges that has more the style of the brooklyn bridge in NY (okay that is not a steel/brick construction) but I like the style of these old bridges.
    Chohole said:
    yes I know and in a comment above I have written that this set comes near to what I am looking for :)
    but this set is a bit small, I will buy and use it but some other destroyed bridges that style, maybe with a road on top and not wood planks and a bit larger would be cool, too
    edited August 2015
    http://www.daz3d.com/high-cliff-crossing
    Maybe you could modify or retexture for what you need?
    Post edited by fixmypcmike on
  • jerriecanjerriecan Posts: 470
    edited August 2015
    Try this set:
    http://www.runtimedna.com/Apocalypse.html
    Has a large bridge section like the Brooklyn Bridge and various rusty steel building frames.  Also, free. :)
    Also, if you find other similar sets, please share - I'm looking for similar resources.
    Post edited by jerriecan on
  • CybersoxCybersox Posts: 9,924
    edited August 2015
    http://www.renderosity.com/mod/bcs/outside-world-part5---south-valley-and-highway/110453/
    http://www.renderosity.com/mod/bcs/sw-the-bridge-2-for-poser-/76944/
    Both need minor material adjustments for optimal performance in DS, but seem to work fine otherwise.  Both vendors make a number of other products that may fit your needs.
    Also, Adam Thwaites also has a nice little construction set called Steel at Most Digital Creations, that's good for this sort of thing.
    Edit - Typed "optimal performance in Poser" when I meant "in Daz Studio".
    Post edited by Cybersox on
    jerriecan said:
    Try this set:
    First, many thanks, that comes real close to what I am looking for. If I see something like this at other stores I will let you know. There are some products like this at TurboSquid but there you have to pay an amount of money :) so
    Both need minor material adjustments for optimal perfomrnace in Poser, but seem to work fine otherwise.  Both vendors make a number of other products that may fit your needs.
    many thanks to you also, well I think one or two of of all these sets will be added to my content :)
    cosmo71 said:
    jerriecan said:
    Try this set:
    Glad to help. :)
    jerriecan said:
    cosmo71 said:
    jerriecan said:
    Try this set:
    Glad to help. :)
    ...and here it comes...my first render with the free destroyed bridge from RDNA...once it was a nice place in town
    1650 x 875 - 361K
  • Oso3DOso3D Posts: 15,116
    Very nice!!
    Agreed, great image! :)
    thank you :)
