strand-based hair fitted on geograph does not follow model pose
Hi there
I have a model with a geograph (golden palace)
and I created a strand-based hair based on golden palace object (not the geometry shell)
I fitted and parented it on the geograph.
I posed the model, everything was good.
When I now load the scene, the hair is away and when I move the model the hair is moving in other direction.
I can only fit the hair in the geograph or it says it cannot fit because the geometry differs.
I have no idea what I made wrong.
Any idea someone ?
Thank you
  • mricmric Posts: 8
    Finally I have it working.
    I created the hair based on the geometry shell but I did not fit it at creation time.
    After that I fitted manually to the geometry shell and I parented it to the figure (which is also parent to the geometry shell).
    I have the impression that it does not work when I fit the hair when I create.
    => Does anyone understand and can explain to me ?
    618 x 459 - 111K
  • lilweeplilweep Posts: 2,867
    your first mistake.
    Dont parent SBH hair to the object it's fitted to.  It should be unparented to the fitted item.
  • mricmric Posts: 8
    thank you for your answer lilweep
    yes indeed it is working when the hair is unparented & fitted to the geometry shell
    which is fitted and parented to the figure
  • mricmric Posts: 8
    in fact so far I had to create a group that contains both the figure and the stranded based hair.
    I find it dirty but it work.
    If someone has a better way I am interested.
