Octane render issue
Hi,
I've got 2 big issues with Octane render
1. I can not select anymore an object or a character from scene (left screen), it says octanerender scene data 1xxxxxx, I have to go to right screen (viewport, scene, environment) and select it
2. Scenes seem to be very long to charge (it wasn't the case so far since I've noticed octanerender mentions)
Best regards
Christophe
1. I am not sure what you mean in 1 - perhaps you could give the names of the panes you are using. However, if the issue is proliferating Octane Scene daat nodes, possibly redundant, that will have an impact on load time. If you are laoding the same saved assets more than once you might be ending up with more than one copy of the associated data node (look for (2) and so on after the label).
You can clear out the Octanerender nodes using this sample script http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/elements/remove_prefixed_data/start
Hi, Christophe. If you're using the OctaneRender for DAZ Studio plugin, please make sure you have the latest version, which you can get from https://render.otoy.com/forum/viewforum.php?f=44. You might have better luck asking question in that forum as well.
As Richard said, it's not very clear what you're describing. Consider attaching screen shots showing the probem.
Regards,
Toby.
Thank you Richard for your help, I will try
Thank you both of you for your help, I will try
Best regards
