Possible to edit existing strand based hair?
This product shows that it uses dforce strand-based hair
dForce Togatta Hair for Genesis 8 | Daz 3D
But when applied to a character the icons in the scene view next to the hair nodes dont show as strand based nodes and attempting to edit them with the strand-based editor gives the expected message of "a strand-based node must be selected".
Are these somehow locked/converted once they are published that prevents the end user from editing them with the strand-based editor?
Thank you for any help!
  • Yes, the Strand Based hair is converted to dForce hair which if different and not backwards-convertible. dForce Hair can also be made from imported geometry without touching the Strand Based hailr system
  • mostlyhumanmostlyhuman Posts: 94
    edited December 2022
    Ahh, okay. Thank you, Richard.   Is there any way to reduce the total number of dforce hairs that show in the viewport by default?  I lowered some of the settings in the Surfaces but there was a minimum value where the hairs would not reduce beyond that point.
    I am exporting what is visible in the viewport and then using them as guides in Maya Xgen but there are way too many by default. I only need about 5% of what it shows by default.
    Post edited by mostlyhuman on
