Using a G8 geocraft/geoshell on a G8.1 figure
Hey everyone,
As described in the headline I want to use a G8 geoshell on a G8.1 figure, but if I try it just says I have to select a G8 figure. In my specific case it is Breastacular by Meipex. I can load the geoshell on my G8.1 figure but I can't copy the material, so the surface stays white. Of course I already informed myself and know that it is because of the different UV maps and Body surfaces G8.1 has. I also found a solution, simply copy the body material from G8 to G8.1 and change the UV map to Female Base. So all I wanna know is where exactly I can find the materials/surfaces and where exactly I have to copy them, because I can't figure that out by the descriptions given to me. Thanks in advance.
Cheers
