How to achieve a certain look?
I'm trying to see if I can copy the look of the movie Repo! The Genetic Opera, with its kind of fuzzy look and tone. Any ideas?
Shilo's nightgown with black stretch lace sleeves | Repo the genetic opera,  Fashion, Genetics
  • frank0314frank0314 Posts: 15,115
    What exactly are you trying to copy?
    The way how everything looks a bit fuzzy and has a certain color scheme to it. It looks a bit over exposed.
  • try turning on Depth of Field in the camera (you need to use a ral camera, not Perspective View) but make sure the Focal Distance is in front of or behind the things that will render, then experiment with the fStop setting on the camera (the smaller it is the sooner things will blur). If you switch to Perspective View but keep the camera selected you will see guides on the camera that will let you drag to set the Focal Distance and the width of the in-focus area.
  • HylasHylas Posts: 5,346
    Use bloom; and you can desaturate and adjust the colour tint in Render Settings -> Tone Mapping
