Curly hair with bangs?
Does anybody know of any hair like this for G8F?
Stranger Things season 4: Behind-the-scenes secrets that will turn your  world Upside Down | Glamour UK
  • IceCrMnIceCrMn Posts: 2,332
    Linday's Bang Bob hair is close.
    It has a curl shaping slider(adjust this AFTER the sim or the curls get flattened out) that gives that gentle loose curl shape like in your example image.
    Also has several shapes for the bangs that are separate from the rest of the hair.One of them would get you close.
    http://www.daz3d.com/bang-bob-hair-with-dforce-for-genesis-8-females
    Unfortunately, it doesn't have the sides combed back.
    It is dforce, so you might be able to something with that if you've got the time and creativity to get an animation sequence worked out that will give you that shape.
    I worked one out a a few months back using a torus that scaled down in size during the sim animation and the character starting upside down at frame zero to put this hair in a ponytail.
    Maybe putting her hands though her hair up to certain point can push the sides back.Just stop the sim when you get the shape you want.
  • TaozTaoz Posts: 10,308
    edited December 2022
    Maybe this:  https://www.daz3d.com/ayako-hair-bow-for-genesis-8-female-s
    It also has behind the shoulders morphs for both sides which aren't shown on the promos.
    The bangs get some odd artifacts when you make them short but you can trim them off with the Geometry Editor which I've done here.
    804 x 962 - 1M
    530 x 300 - 34K
    Post edited by Taoz on
  • CybersoxCybersox Posts: 9,639
    I find that it's often easier to kit bash a bit than search for the perfect hair.  I'll often apply two different hairs at the same time and hide the front of one hair and all but the front of another to get effects like that.  There's also a very useful package from Biscuits over at Rendo of just hair front pieces.  Those were made for V4, but they can be parented to any Genesis figure and then color matched in easily.
    Post edited by Cybersox on
