G8.1 M Morphs and Materials on G8M?
I thought that the G8.1M morphs and materials could also be applied to G8Ms. I tried this with Trance, and nothing gets applied. Here's Trance: https://www.daz3d.com/trance-hd-for-genesis-81-male
Is there a way to apply this to a G8M?
  • nemesis10nemesis10 Posts: 4,009
    The morphs should appear in your shaping tab.  8.1 has both 8 and 8.1 UV's while 8 just has 8 UV's so some elaborate map transfer would have to be done to apply materials.
  • vwranglervwrangler Posts: 5,045
    Not offhand. G8.1 morphs and textures are not backward-compatible with 8.0. The UVs are different, and 8.0 can't "see" the 8.1 morphs, although 8.1 can see and use the 8.0 morphs.
    You can probably do a map transfer to write new versions of the 8.1 textures to work with 8.0, but that doesn't help with the morphs/shapes, I'm afraid.
