V2 Released: Tile or Re-tile your textures - Script for DS 1, 2, 3, 4
mCasualmCasual Posts: 4,607
edited August 2015 in Freebies
Right Here ====> https://sites.google.com/site/mcasualsdazscripts6/mcjtiletex
example, you have a brick texture image and in your scene you applied it with custom tiling and custom offsets
but you want to use a shader that doesnt support tiling
or
you want the bump map to use a different tiling, but most materials have only 1 tiling/offset setup
with the  (upcoming ) script mcjReTileTex
you select a surface
the script lets you select which image to mcjReTileTex
you press a button and using imagemagick a free utility not-by-me
you get a new texture image that looks the same when applied without any Tiling ! ( well with a tiling of 1 by one with no offset )
i made this because the bump map currently displayed on the apron needs to be "manually" reworked and the tiling didnt make this easy
in the image below the top surface has a tiling of 4 by 4 with a vertical offset of 0.33, that image is 472x472 pixels
the bottom image is 1888x1888 pixels and has a tiling of 1x1 with no offset
800 x 1000 - 521K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited August 2015
    since DS doesnt have an image.paste() function, i guess i wont make a version of the script that works without imagemagick
    shown here: selecting more than 1 material
    now i only have to add a button, so you can tell where you installed imagemagick
    someone please tell me
    is it normal that i have to re-upload images twice in this forum, else they sometimes get corrupted or something?
    498 x 608 - 180K
    800 x 600 - 270K
    800 x 600 - 231K
    edited August 2015
    close to the finish line ...
    to keep everything simple,
    negative tiling values will be forced into positives
    i.e.
    if( tiling < 0 ) tiling = -tiling;
    if a tiling setting is 0, it gets forced to 1
    Tiling offsets will be remapped to the 0 to 1 range,
    but they'll remain functionally equivalent to your negative offsets
    so you can use negative offsets and get faithful results
    800 x 600 - 231K
    edited August 2015
    it's a quick way to make pattern textures !
    see i can zoom in on something, render it, apply this image to a plane, tile it
    then i use the script and bam i got a tiled texture
    i was hesitating, but i think i'll make the output filename and type selectable by you
    instead of having an automatic name and location
    then i post the script and you can play with it Sunday !
    1000 x 1000 - 688K
    edited August 2015
    The Early-Nerd-Gets-The-Script version is out !
    182 x 182 - 2K
    516 x 372 - 67K
    edited August 2015
    there will be a second and final version today
    it addresses the issue when using tiling of less than 1 - for example here the vertical tiling is 0.5
    to make matters more complicated, OpenGL and 3Delight dont handle it the same way
    i'll also make tests in DS4.8 ! and IRay ... and possibly Blender
    so it's clear mcjTexTile interprets the tiling for sub-1 tiling the same way 3delight does
    left is hardware/preview, right i software render in DS3
    1514 x 776 - 602K
    1674 x 772 - 720K
  • mtl1mtl1 Posts: 1,508
    Oh wow, thank you so much. I can see so many uses for this script already ^_^
    edited August 2015
    so there will be a checkbox
    when the vertical tiling is less than 1 and this checkbox is checked,
    mcjTileTex will do the same mistake as the Daz Studio OpenGL preview does
    for the record, here's the code for this
    	if( wcbViewportAlike.checked )	{		if( matVT &lt; 1 )		{			matVO = matVO - matVT;			if( matVO &lt; 0 )			{				matVO += 1;			}		}	}
    Indeed the behavior is the same in DS4.9 as DS3
    i.e. for sub-unit vertical tiling
    the preview shows one thing the 3delight render shows another
    so the new checkbox will help!
    note that the test testure is a public domain picture from 1001 nights
    http://karenswhimsy.com/arabian-nights.htm
    but IRay treats sub-unit vertical tiling like the OpenGL viewport
    i swear i didnt notice the black skirt visibility was off
    and anyway she's wearing the mcjA3Bodycon and panties
    516 x 397 - 66K
    1312 x 898 - 577K
    720 x 720 - 1M
    edited August 2015
    In the case of Blender Cycles
    the scene exported from DS4.8 using mcjTeleBlender
    Failed ... which is a problem i will look into soon
    the tiling didnt make the voyage from DS to Blender
    in fact i'll check right now if DS3 does it too
    but in a way, you could say mcjTileTex solves that type of problem !
    since it integrates the tiling in the texture file
    the lower left panel is the mcjTileTex texture ! and it's A-OK!
    oh i see the problem
    in DS4.8, when DS's OBJ exporter exports the scene
    it renames some materials to avoid material name "collisions"
    mcjteleblender does transmit the tiling for "Plane_7", material "Default"
    but in the .obj and the .mtl, calls the material  "Default_Plane_7"
    ... expect a TeleBlender3 (and 2 ) update soon ...
    though TeleBlender under DS3 works fine, and since i'm quite often in the comfort and security of DS3, i didnt test/fix teleblender-DS4
    even the "collect maps" options has issues under DS4 dang it
    The Vic-20 and PET versions are a-OK
    see? DS3 + TeleBlender --> Blender Cycles, No problem
    720 x 720 - 194K
    800 x 720 - 315K
    edited August 2015
    a pattern created start to finish under 5 minutes though it could be done in 30 seconds if you have the source image already
    so today i plan to release the 2nd and final version of mcjTileTex aka mcjTexTile
    you can download the attached images and use them how you please, the flower is a prop i made
    ( and may publish someday since apparently i didnt )
    2048 x 2048 - 594K
    256 x 256 - 25K
    edited August 2015
    So version 2 is released!
    it includes the option for the special case wherein the vertical tiling is below 1 tile
    and it includes the tested/fixed version for DS1/DS2
    now you may say, but but DS1 does not have tiling
    ah HA! then you should look into my free shader for DS1/DS2
    it even has separate tiling for the bump map ( https://sites.google.com/site/mcasualsdazscripts2/mcjglossy )
    91 x 91 - 6K
    91 x 91 - 7K
    728 x 728 - 310K
