Zbrush GOZ object duplicates
kaltland
So everything was working until I updated zbrush. I'm trying to use Goz with daz3d studio but in Zbrush, instead of exporting the object duplicates itself every time I click the GOZ button... nothing happens
GoZ from Daz Studio is one-way trip: I can send a model over to ZBrush, no problem. It's sending back to Daz Studio that's the issue.
* Latest DS version
* ZBrush 2022 0.6, current version.
* Macbook Pro, 10.14.6 Mojave
* All paths are linked to where they should be in DIM
* Yes, I have tried clearing the ZBrush GoZ cache several times now and relinking it to DS several times now
I tried again using the frameworks trick, but this time it didn't work... the result in terminal is:
ln -s /Applications/DAZ\ 3D/DAZStudio4\ 64-bit/Frameworks /*.* ./
ln: .//Frameworks: File exists
ln: .//installer.failurerequests: File exists
Duplicates itself in DS or ZBrush? If it's in DS, did you save it over at base resolution or current resolution? Morph making requires the former (and that the mesh is not divided in ZBrush when you send it back).
