[Solved] Iray help! Environment disappeared
Ralf1958Ralf1958 Posts: 688
edited August 2015 in The Commons
Hello! How do I fix this? Never had that before. I loaded an old Prop and at the same time the Iray environment disappeared. The Background of the viewport turned white and renders transparent. If I add an environment map it works fine. It's just the normal environment Sky and Ground that's not there anymore. I checked everywhere, shut down, rebooted... nothing... how do I get it back??? Thanks!
Post edited by Ralf1958 on
  • Ralf1958Ralf1958 Posts: 688
    Problem solved!
    edited August 2015
    For the record, if after loading an item, your Viewport Background color changes to white for no obvious reason, you just need to go to Window/Style/Customize colors and set back to Defaults. smiley
    There are options in Preference to ignore background color changes when loading a scene.
    Not talking about loading a scene but loading an object into an existing scene and the scene turns white for no reason.
