easy method of fitting genesis 1clothing to genesis 3
Zantetsukens-cut
i don't have time to check the entire forum area to see if this has been talked about. so im just going to mention it
i found a easy way to fit genesis 1 clothing fit perfectly on genesis 3. if you try to transfer clothing directly from genesis 1 to genesis 3 it looks very bad because an auto fit projection template is only available for genesis 2 and the clothing item is genesis 1 weight mapped.the solution is fist project the weight mapping template of genesis 2 to the item. so load up genesis 2 and auto fit the clothing to it. now the item is technically a genesis 2 clothing item after that fit the item to genesis 3 because the weight map on the clothing now matches the one used in the auto fit script it will fit genesis 3 perfectly. and if it still pokes through a bit just apply a smoothing modifier to the clothing item.
i hope this helps someone . have fun
