[HELP] Gen3 tank-top convert to Gen2
I recently purchased the tank-top set for Genesis 3 female (http://www.daz3d.com/fm-tank-top-panties-pack-for-genesis-3-female-s) and hoped the auto-fit funtion would fit it well to Genesis 2 female base.
Although it does fit well enough (auto-fit: upsupported, shirt) there is still a noticable gap around the cest, and it also seems to push forward and cuts into the back while leaving a gap at the front.
Even when I set Expand Waist 100% and Epand Waist Low -100% / 100% it still cuts in and has gaps. (Also relas doesn't help)
Is there any way I can fix this?
Cheers
Doesn't work that way — autofit on a G3F figure only lets you convert G2F clothes, and autofit on G2F only converts Genesis (original) clothes. There are extra autofit settings that can be bought in the store, to let you use autofit on other figure/clothes generations, but G3F is too new; there isn't anything out for it yet. And as you've seen, unsupported autofit conversions sometimes don't work very well. Give it a bit of time, and someone will probably create just the thing you need.
For that, a smoothing modifier may help...make sure, after fitting and using the expansion morph that the Smoothing modifier is on and that the collision object is G2F.
