How to create a morph for the head only ?
I want to create a morph only for the head, using a character with a compatible mesh, but Morph Loader Pro will make a morph for the whole body.
I tried to use Morph Loader Advanced, but if in the combobox of this utility I select the head, it creates a faulty morph that distorts the whole body.
Of course, in my 3D software I could create a compatible mesh by taking the head I'm interested in and gluing it to the base body, but there's probably an easier way to do that.
  • Richard HaseltineRichard Haseltine Posts: 112,049
    edited November 2022
    Morph the whole figure msh, but don't change the bits you din't want to chnage - if the only changes are to the head then it will be a "head morph". A morph is just a list of changes in position, if the change is zero in a given area the morph will have no effect; morphs add, so having the default shape won't prevent you from applying other shapes.
