is the a way to set parameter's translate and rotate increments
VicSVicS Posts: 1,273
edited November 2022 in Daz Studio Discussion
seems g8f moves in tenths , and objects in 1 full whatever the measurement is
are there settings?
thanks
Post edited by VicS on
  • NorthOf45NorthOf45 Posts: 5,896
    Tool Settings tab -> Universal gizmo -> click on the appropriate Snapping button, and set the value. It is a global setting, not per object.
  • StratDragonStratDragon Posts: 3,289
    select the gear icon on the right side of the parameter you would like to adjust
    change the nudge value
    you can also remove the limits of the min/max values
    364 x 179 - 13K
    751 x 269 - 20K
  • VicSVicS Posts: 1,273
    awesome, this will make lifew easier, thanks NorthOf45 and StratDragon!
