(Solved) Problems with Autofit and Clothes Genesis 3 to Genesis 8.1
Hello all,
i will put some G3 male clothes (T-Shirt) on the G8.1 male standard figure and when the Autofit Window open it look good but when i select G3 Male in the Autofit Window and press Accept the clothes jumped in the T start pose of G3.
I tried with the G 8 standard figure and it works fine.
Can anybody help me ?
Thanks all :)
Post edited by methusalem210035 on
Are you sure it is a Genesis 3 item?
Yes i tested with clothes of Mr. Cogsworth Outfit, Laid Back Outfit or Crimsons Seas Outfit (all for G3) from the shop.
All clothes (Shirt, Trousers...) the same. G8 Basic Male works fine but with G8.1 the clothes go in G3 T start position.
I`ve tested with Female 8.1 and clothes for G3 female there is no problem.
If I might suggest to try using my T <=> A autofit clones {links in signature}.
Hi Chaterine,
i tried it and it works fine with your clones :)
It´s an easy and good solution for me so it´s perfect :)
Thank you
You're most welcome, glad it worked for you too :-)
