Putting Genesis 2 clothes on Genesis, M4
Can I use Genesis 2 clothing on V4/M4 and Genesis?
I know that you can turn a Genesis 2 character into M4/V4 with the correct morphs...so it seems logical that you'd be able to put Genesis 2 clothing on M4/V4. But I just wanted to make sure before moving forward.
Thanks
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,853
    I can in DAZ studio by making V4 etc triax, and using V4 clone from Mallenlane or M4 from Slosh on clothes and using unsupported in fit to or transfer utility then creating a cr2 export with an obj geometry file, it even works in DS3 but sadly not Poser or Carrara.
    bit more to it, need to refind the thread
    otherwise Crossdresser 4 using a cr2/companion file with obj, it is important to have or create the obj as most DSON does not.
  • fixmypcmikefixmypcmike Posts: 19,743
    There's a G2 autodfit clone for Genesis, so that's easy.  The difficulty going to M4/V4 is the rigging.  I don't know what apps like Crossdresser and Wardrobe Wizard support these days.
  • almahiedraalmahiedra Posts: 1,374
    XD4 can convert from genesis to other figure. I only could test with pippin and others free license figures, but outputs were Ok . You need to know how save cloth to cr2, next, use XD as usual.
