Tablet Mode?
I installed DAZ Studio on a Dell Venue Pro 8 tablet, along with Poser. Poser can be set to Tablet mode in it's preferences and works well with the pen. Although it is incompatible with Windows 8.1 unless you adjust the .ini file to use the external library. Although I can get Poser to work well on this tablet DAZ Studio has a problem with both touch and the pen. I need to set it to tablet mode in much the same way as I can with Poser. Is there a way to make such a setting.
I think the sampling for the pen or touch screen gets interpreted as another movement so you get a tumbling effect. It is possible to move objects using the arrow system around the figure but the actual controls randomise by adding the sampling speed as a movement. I seem to recall something like this on DAZ Studio 3 but can't be certain. I've looked but can't seem to find a setting?
The result here is that I also found that Iray was missing. DAZ Studio was installed twice, once entirely using the DIM but no Iray? Perhaps it's not compatible with this hardware. It would have rendered in less than 2 hours judging from the Mac Pro CPU render. So no tablet mode, and no Iray, thus removed. Poser Pro 2010 has Tablet Mode, and it's render engine works fine despite the program being incompatible with Windows 8.1, thus superior. Even it's interface was fully customised to work well in Portrait mode. So despite being 5 years old it is still better than DAZ Studio, which is why no content is purchase from DAZ.
I would have expected it to work?
Iray is only available in the 64 bit version of DAZ Studio, were you aware of that?
