I accidentally closed the Panes. How do I get the Panes back?
I accidentally closed the Panes pressing the X button. Does anyone know how to get them back.
  • felisfelis Posts: 6,563
    You can find them under Window > Panes (Tabs)
    And if wanted you can dock them at one of the sides, by dragging it to the side where you want it, and release when a yellow line comes up.
  • If you were using something closer to a default layout, you can go to window>layout> select the layout you were using. That's also where you save your layout if you want to keep whatever customizations you have in case something like this happens in the future.
  • And if you have closed some, but not all, panes in a group you can add them back (or add others) by right-click in the tab well, the area in which the panes' tabs appear.
