Batch Convert M4 to Genesis 2
Could someone PLEASE give me step-by-step instructions on how to use Back Convert M4 to Genesis 2 Material Files?
Namely I'm confused about "Under Source Material Files".
Select Folder and its Subfolders to convert (which folder?)
Select Material Files to Convert (which matertial files? Does this mean the textures or the folder under materials? What if there are no files under materials? Where then might the material files be? Tried the Texture folder for the figure, but the only option is png while texture files are in jpg...should I convert these to png?)
HELP.
  • LeanaLeana Posts: 13,616
    edited July 2015
    The batch converter will convert material presets for M4 (pz2, dsa, ds) into duf for G2M
    Select folder = add the folder which contains the material preset files you want to convert, and its sub-folders if you want
    Select Material files = select the presets you want to convert, in case you don't want to convert all the files in that folder (for example if you have a folder with MAT for clothes and a character, you'd select only the MATs for the character. Or if you have too many presets in the folder, you can do it in several batches)
    Post edited by Leana on
  • SwanSwan Posts: 134
    Thank you for the help!
