Shark Tail for Genesis 8 Males
enchantee790enchantee790 Posts: 49
edited November 2022 in Daz Studio Discussion
Hi all,
Hopefully I can get some help again. I bought [Shark Tail for Genesis 8 Males] the above package and cannot get the geoshell to work.
The character takes on the defaul grey shark look, the warpain and scars will not show at all.
The Geoshells will change on the entire body masking the chest that should be bare too.
I tried with only the tail to see changes nothing :(
Anyone has a guide? I followed what the documentation says but seem something is not right
Thank you
  • GordigGordig Posts: 10,797
    Have you tried rendering? I believe the geoshell uses things like diffuse overlays, which don't appear in the shaded viewport.
  • As Gordig mentioned, the war paint and scars will only show up once you render. I also replied here with the same information: https://www.daz3d.com/forums/discussion/comment/7829386/#Comment_7829386
  • Also, just in case, remember to select the geoshell wearable before applying any of the presets. :)
  • Thank you everyone. I will try your suggestion. Still only getting spots on mr Shark but try with more setting. I'm certainly doing it worng as I see tons of people got theirs right. Thanks for the input❤
    If you could provide screenshots or more information as to the process you're following, I'd be happy to help you trouble shoot. But it's important to understand that with this particular product (due to the shader being used) you will only really see the changes once you render and it should render the same as the icon, provided you are using the geoshell wearable and selecting that shell before applying any of the presets, of course!
    Months later..sorry for the late reply. It worked after I change my graphic card. I managed to use iray. Loveee the shark boy.
