Are Parameter Slider background colors globally adjustable?
BrycescaperBrycescaper Posts: 150
edited November 2022 in Daz Studio Discussion
I have the latest release of DAZ and the Face Transfer Plug-In, and when using that to creatte custom characters I have several go-to parameters to adjust the generated figure, such as close mouth, mouth realism, HD lip contours, young face and adusting the jaw corner width. In Parameters I can change the color of the slider background color to tab or flag these parameters I tried it on one figure and thought, "I'm set. Every Genesis 8 figure will have those same parameter sliders an assigned color than the ones around it, and I can convert figures more quickly". Turns out that these color adjustment colors to highlight the most used function apply to that figure currently loaded and not to others of the same base figure (in fact, every Facetime character has the default character name, 'Genesis 8 Female'.It's really a pain to manipulate the slider back and forth and find the parameter by reading the fine print. The same applies to Favorites as far as I have tried it, there should be a user-defined global "flagging' system that applies to all figures named "Genesis 8 Female."  Is there a way to do this like is done by vendors applying custom colors to distinguish their morphs added into the content library? Thanks for any input you can provide.
Post edited by Brycescaper on
