How to get rid of default light in iray render
No matter what I try, I always seem to have a default light from the right:
  • New scene
  • Add plane
  • Add cube
  • Add camera
  • Turn ‘headlight’ off in new camera
  • Render using new camera
I’m expecting a black scene. Even if I add a spotlight, turn its intensity to zero AND point it  way, I still get the same render.
Where is this light coming from?
Thanks.
880 x 680 - 122K
    By default, I believe, that Iray is set to Scene and Dome.  The light is coming from the default HDR loaded into the dome.  If you switch to Scene only, under Render Settings > Environment, that should give you the lightless scene you are after.
  • rol3drol3d Posts: 40
    Thanks mjc1016, that is the fix!
  • Oh thank goodness. That was driving me crazy!
  • Do you know how long or how much this bothered me? Unholy Fekk!
    Thanks so much, I feel like a dummy for not searching this sooner.
  • nelsonsmithnelsonsmith Posts: 1,337
    Thank goodness these threads are always here.
