HELP PLEASE - iRay Preview not working correct
Hello
I have troubles with the iRay Preview. It doesn't show/render the lights that come from surfaces/objects in the preview mode. The surface itself is rendered as a light, but it has no influence on its environment, all objects stay dark/unlit. The preview works fine with Environment and stuff in the render settings.
I have an Nvidia rtx 3070 and the daz version is 4.21. I tried roll backs with the Nvidia drivers to several older driver versions, but this didn't change anything.
The final renderings are fine. Watch attached windows with the red light (one shows the preview window/mode), the other the final rendering.
Anybody knows the reason and could help me?
Thanks in advance!
Stephen
1226 x 1270 - 40K
1237 x 1281 - 199K
That might be your Draw Settings.
Try Photoreal
Thank you very much! That solved it!
