Which pane should be specified for morphs such as hair
Hello,
I used Morph Loader Pro to create a morph that transforms a prop.
In order to distribute it to my friends, I wrote Readme.txt to operate the transforming properties from the shaping pane, but the parameters pane also shows the morph loader properties in the same way.
For my study, please tell me the following.
1) If I create a prop with morphs like this, is the pane in which the user should typically morph the parameters pane morph? Is it still a shaping pane?
2) If it is correct for the user to use the morphs from the shaping pane, I would like to hide the morph folder in the parameters pane so that the user does not make a mistake.
-There was a "hidden" function in the submenu of the morph folder in the parameters pane, so I used it, but I couldn't actually hide it.
Please forgive me if the English is hard to read due to machine translation.
Thank you.
  • It is not a mistake. It is okay to have morphs showing in both Panes.
    The 'hidden' function is for different types of files, such as corrective morphs that the user does not need to see or use.
  • Catherine3678abは次のように述べています。
    間違いではありません。両方のペインにモーフを表示しても問題ありません。
    「非表示」機能は、ユーザーが表示または使用する必要のない修正モーフなど、さまざまな種類のファイル用です。
     I learned.
    Actually, a user asked me to hide the morph folder in the parameter pane of all the props I will be distributing, as it would be annoying if it was displayed.
    I understand that there is no problem even if it is displayed, but is there a way to hide this folder?
    Thank you for answering.
    366 x 264 - 12K
  • barbultbarbult Posts: 27,611
    That user does not seem to understand Daz Studio very well. Hiding your morphs in the Parameters pane would be the confusing and nonstandard thing.
  • バーブルトは次のように述べています。
    そのユーザーは Daz Studio をよく理解していないようです。パラメータ ペインでモーフを非表示にすることは、紛らわしく、非標準的なことです。
    I agree with your opinion.
    If there is no way to hide it, I will politely decline this user's request.
    edited November 2022
    Yes, decline his request for it is not reasonable. We actually LIKE to see our morphs show up on either pane so we can use them!
    If you move the morph out of Morph/Morph Loader to say General > Actor > Props or something, then the header for Morph/Morph Loader will vanish.
    If you move it to "hidden" and set the morph to be "hidden" then it would be hidden, as far as I know "everywhere" including the Shaping Tab. Things that are hidden can be revealed if the user toggles the choice to show hidden. {from the hamburger {bunch of lines} menu}.
    Post edited by Catherine3678ab on
    はい、合理的ではないため、彼の要求を拒否します。私たちは実際にモーフがどちらのペインにも表示されるのを見てみたいので、それらを使用することができます!
    Morph/Morph Loader からモーフを移動して、General > Actor > Props などを選択すると、Morph/Morph Loader のヘッダーが消えます。
    それを「非表示」に移動し、モーフを「非表示」に設定すると、シェーピングタブを含む「どこでも」知っている限り、非表示になります。ユーザーが選択を非表示に切り替えると、非表示になっているものが表示されます。{ハンバーガー {線の束} メニューから}.
     understood.
    I learned a lot.
    Thank you.
    You are welcome :-)
