Apollo by Gypsy Angel
Banbha
Hi, this is a technical issue regarding the Poser files for Apollo. I want to use this texture in Poser but when i go to use the material settings, all that comes up is just the texture map and if there is another texture set (for instance the default male) with all the shaders, it will only add Apollo's texture to the empty Diffuse node. There are no shaders, no bump maps, no specularity maps set with the Poser material setting for Apollo. I don't know if anyone had checked this compatibility in Poser but I will say for me, it doesn't load properly.
Liesel
