Neko model missing textures
Hi,
I bought Neko HD model,
https://www.daz3d.com/neko-hd-for-genesis-8-female
Trying to apply the textures, then running iray crashed my daz to desktop,
Looking at the logs and this shows before the crash:
2022-11-01 20:05:39.434 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "E:\Work\DAZ3D\Applications\Data\DAZ 3D\My DAZ 3D Library\Runtime\Textures\Raiya\Neko\RyNeko_torso_1002.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2022-11-01 20:05:39.436 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "E:\Work\DAZ3D\Applications\Data\DAZ 3D\My DAZ 3D Library\Runtime\Textures\Raiya\Neko\RyNeko_torsoS_1002.jpg", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
2022-11-01 20:05:39.477 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "E:\Work\DAZ3D\Applications\Data\DAZ 3D\My DAZ 3D Library\Runtime\Textures\Raiya\Neko\RyNeko_torsoNM_1002.tif", no selector, pixel type "Rgb", 4096x4096x1 pixels, 1 miplevel.
Or maybe its something else?
Thanks in advance.
  • It's the .tif file normal maps. They for some reason crash iray in recent versions of daz. Convert them to .png or remove them before rendering.
  • JubeiJubei Posts: 29
    I'll try thanks!
    @zombietaggeru tried to change the normal to png - still crash when I run iray
  • How about removing them completely? And check anything else you may have in the scene as well for wayward tif files.
    trying
  • TaozTaoz Posts: 10,346
    Will that not break some references?
    It could, only if you overwrite the originals with the new, though. Which I do not recommend. But, assuming the character/prop/set has been used in a previously saved scene, it's not too hard to reopen the old scenes and replace the tif files with the new png files.
    I removed all the tif
    changed all tifs to png
    then removed them, but still it crashes when I start Iray - even in viewport
    not to mention when I send it to the render farm...
    Interestingly enough IF I change all the textures - i.e. from another product - it works fine
    now it gives me:
    DAZStudio.exe caused ACCESS_VIOLATION in module "E:\Work\DAZ3D\Applications\64-bit\DAZ 3D\DAZ 3D\DAZStudio4\libs\iray\libneuray.dll" at 0033:000000000768EDDE, mi_neuray_factory_deprecated()+9708062 byte(s)
  • Well, I'm not sure what that error means, so someone else will have to chime in for that one.
    When I change her skin to one from another model it works a-ok!
    with normals and everything
  • hansolocambohansolocambo Posts: 649
    edited November 2022
    I confirm that Neko HD causes an instant crash when trying to Iray Preview or Render.
    - I resaved all jpg textures. Resaved all Tiff : crash.
    - I converted Tiff to png and replaced all corresponding textures on the model : crash.
    - I used the slider to dial the full morph rather than load the character, to avoid using the geograft eyes just in case. But as soon as I applied textures : crash.
    As it's not a material issue, it's probably more a shader issue.
    I won't test further because it's 4:30AM and there are too many things to test with constant crashing before I can pinpoint the problem. But there is definitely something wrong with this model.
    It is unusable as it was sold.
    Submit a ticket about that    ¯\_(ツ)_/¯
    Post edited by hansolocambo on
  • RaiyaRaiya Posts: 89
    Hey guys,
    just a quick note that I'm looking into this but still haven't found a solution either.
