An-Terra or A N Terra Question
Does anyone have this? http://www.daz3d.com/a-n-terra
I am honestly having trouble locating this item. The spelling on the page is inconsistent. So is it An-terra or A N Terra?
It installed via dim, but doesn't show up in the product view. I can't tell if it just has no data, or if there something else going on... Do you have it? If so, can you tell me where yours is?
    It is simple to find anything that you installed using DIM, just find the item in the Installed tab, right click and then select 'Show Installed Files'.   That will give you the library name and the path that all the files were installed to.
    Hey thanks JimmyC, I learned something new. I will check it out. =-)
    Hmm, still not finding it. found the texture under animals but not the figure. Anyone else?
    Okay, well, I think it's an installer problem. I'll submit a ticket. Manual installer loads the files, just not the dim... For some weird reason.
  • MarcCCTxMarcCCTx Posts: 947
    Do you have Frida's Ant http://www.daz3d.com/fridas-ant-fernando-by-the-antfarm. An-terra is just a texture for this product.
  • carrie58carrie58 Posts: 4,144
    You should be able to find the Ant Figure in the character folder, since it's a Cr2. .......
    MarcCCTx nope flip that An-Terra has the figure and  FRidas Ant Fernando is just a texture to turn the black ant red .......
    Oops
