Features request: Apply to all
I'm not sure if anyone else feels the same as I do, but I use the autofit feature regularly to apply previous generations wardrobe items to G8 and it isn't always logical. When the box pops up I tell it which generation the item was intended for from the first drop down, then I click 'Accept'. There is a short delay, and I am asked again for the next item, and the next and the next. For whatever reason there is a delay displaying these options, so I'm clicking on a dropdown that doesn't appear straight away.... and if I'm doing this for a shirt, pants, jacket etc etc etc it can be a little frustrating.
Is it not possible to put a check box that allows the user to apply the same option to all? Like when you are copying files in the OS and you can make 1 decision and it automagically doesn't ask you a hundred times if you're sure you want to overwrite these files.
As far as I know each load is a single, self-contained operation, so I don't think it would be possible to ask in advance and remember the response across each load as the situation stands.
One thing you CAN do, once you've converted the old items to fit the new figure, is save them as Figure/Prop assets (File > Save As > Support Asset > Figure/Prop Assets...). Then, when you want to use that item in future you can load the already-adapted version.
This also has a benefit for the file size of your scenes. If you take an old outfit, autofit it, and save the resulting scene, it makes for a big file size because all the geometry of the modified outfit is stored within the scene. Once the outfit is saved out as a support asset, the scene file will be much smaller. I use lots of older content, and before I realised this I had huge scene files that took ages to load and save.
