Lilim Armour problems
wbrand7wbrand7 Posts: 23
okay just to this is my first forum on this site so i dont know which catogory to put it in.
anyway my problem is that whith the lilim armour that you get with the Lilim Outfit you see when i render the photo the armour is silver in the final picture but when im editing and stuff its its normal colour it doesent happen to the other parts so i would really be grateful if someone could help me
    edited July 2015
    Try removing the attachment and uploading it again as your attachment is broken
    Post edited by Chohole on
  • scorpioscorpio Posts: 8,533
    edited July 2015
    Which engine are you rendering in Iray or 3Delight?
    Post edited by scorpio on
  • wbrand7wbrand7 Posts: 23
    so im having a bit of trouble with the lilim armour shoulderpad, so they are suposed to be black and red with a bit of gold and thats what look like in the textures veiw but when rendered its all just grey can someone help please
     i think its iray and here is what i am talking about
    700 x 910 - 420K
    duplicate threads merged.
    sorry but im a beginner what does that mean
    edited July 2015
    Posting 2 threads about similar problems with the same product in different forums means that answers are likely to be duplicated across the two threads, instead of being concentrated in one. Plus advice can be duplicated as well, which is a bit of a waste of time, considering it is forum members who are trying to help you.
    hey if im causing trouble i am sorry but as i said i am new to these forums so i dont know how they work and yes i understand that forum are trying to help me and i apreciate that truly i do
    and i also thought that no one had commented on my first post since i got no message or something my bad
    We do have a New Users Help forum, would you like to try having the post there, to see if it gets more response. I can move it for you.
    sure thing thanks
    There you go
  • TotteTotte Posts: 15,050
    Is the material for Iray or is it autoconverted?
    If it's not for Iray, I suggest you apply the Iray Uber Base to it, so you have a converted material baseline to work with, then drop the overall glossiness maybe, but you will see how it looks, might be too much metalicy on it too, or too little.
    i dont if it is iray
    and sorry could you explain that in an easier way im a newbie at this
    OK, first which texture did you apply (the name of it), or did you use the default texture?
    default texture since there is only one texture for it so far
    OK, here we go.
    Attached images are Iray default render, 3Delight default render & Iray after my tweaks, plus how I did those tweaks.
    800 x 800 - 62K
    800 x 800 - 58K
    800 x 800 - 54K
    596 x 778 - 89K
    585 x 615 - 99K
    494 x 247 - 91K
    594 x 733 - 82K
    Totte said:
    OK, here we go.
    still no change
    edited July 2015
    Totte said:
    OK, here we go.
    okay i just found out how to get it to work thanks
    Post edited by wbrand7 on
    Great!  have fun!
