Dforce not working at all?
I'm not a big Dforce user, but I've never had any serious issues with it until the last update. Now I've got a problem I can't make sense of.
When I run a simulation, dforce will start up and display the working window, but then halts almost immediately at some point that varies a bit depending on the settings used. I've tried multiple figures and items, even a primative sheet drop, and same thing. Just hangs up.
Pulling up Windows' Task Manager lists Daz as "Not Responding", although using about 7% CPU and about 26gb of memory. (Also listed as high energy usage, if that means anything)
I've left some sims up for several hours to see if things were just very slow, but nothing seems to happen.
've pulled up the log files, but they just cut off (at different points) with no indications of errors or warnings.
I've double checked the advanced settings and have Dforce using my GPU.
I've checked the I've re-installed Studio, cleared catches, updated windows and my Nvidia drivers, and still get a hangup.
I've checked a few other threads but nothing quite fits the pattern here.
I'm running this set-up:
Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz 3.60 GHz
64GB
2X GeForce RTX 2080 Super
Anybody got any suggestions or should I just open a ticket?
There is a known issue with the new nvidia drivers.
https://www.daz3d.com/forums/discussion/596436/open-cl-notify-unknown-error-executing-clflush-on-nvidia-geforce-rtx-3080#latest
https://www.daz3d.com/forums/discussion/596191/solved-dforce-error-error-preparing-objects-to-simulate#latest
You will need to use studio driver version 517.40 until Nvidia fixes it.
Yes, Nvidia is aware of the problem, but no fix yet.
