Sorting the Base Directories?
Is there a way to change the sort order of our Base Directories?  They sort by default by date added and I would like to sort them alphabetically.
Thanks in advance!
  • OmnifluxOmniflux Posts: 442
    Edit -> Preferences -> Content -> Content Directory Manager
    Find the content directory you want to reorder on the right hand side, buttons to change order are in the lower left corner.
  • Causam3DCausam3D Posts: 217
    Thank you Omniflux.
    So basically, I have to do it manually unless I want to move one all the way to the top or the bottom.  There are no automatic sort options.   Am I seeing this correctly?  I ask because I develop content and at any given time my base directories may number 30 or more.  It sometimes gets annoying not being able to find something quickly.  If I am seeing this correctly it's going to be a matter of manually shuffling everything and then doing this for each base directory I add thereafter as soon as I add it.  It's a solution.  I do wish there was a sort order options button though.
    Correct, there is no built in way to sort the directories.
    Attached is a script to do so.
    While I believe you should have no issues with this script, I highly recommend downloading and running the Save Mapped Paths script first, just in case.
    dsa
    dsa
    Sort Content Directories.dsa
    1K
    Thank you sir, I appreciate that very much!
