Product Library
Is there any way to search my purchases by vendor?
  • FirstBastionFirstBastion Posts: 8,088
    edited October 2022
    Only two filters,  By name (alphabetical) or purchase date. In theory,  some vendors now have prefixes in front of the product name  and you could search the prefix. for example 1stB
  • frank0314frank0314 Posts: 15,115
    That is somehting that has been asked about for years, even by PA's. Been asked for both product library and DIM.
    If you have DAZ-Deals, you can filter the shop to show "Only owned" and use the standard filters to pick a PA.
  • LindseyLindsey Posts: 2,017
    The Smart Content>Product tab can search for a vendor.  In the search box enter
    key::<vendor name>
    See attached pic for a sample.
    671 x 989 - 502K
  • CybersoxCybersox Posts: 10,032
    The problem there is that ONLY shows the products that are STILL in the store.  Thanks to how many PAs have exited in recent years and the various purges of the library by DAZ, I have a massive number of products that don't show up that way.
  • hjakehjake Posts: 1,347
    edited October 2022
    You can Export to csv format in DIM after you select all items on your Ready to Install tab and then repeat on your Installed tab. Import the csv file into LibreOffice Calc or M$ Excel. If you have downloaded all software packages then everything you own from DAZ, which can be used with DAZ Studio, will be in these lists plus additional information about your products.
    This will not show the vendor name, but it will let you search library by product ID, order date, porduct name, installation location.
    See attached picture as an example
    1343 x 1019 - 111K
    Post edited by hjake on
