Any way to change character's height?
I am working on a scene with multiple characters and I need to change their heights to match the reference sheet I was sent. Is there any way to do it?
I have being changing some part of the bodies to make then "shorter or taller" but I need something with more precision to have an exact height to each characters.
  • LorraineLorraine Posts: 1,056
    There is a 'Height' morph in the body shapes morph pack for G2, G3 and G8/8.1...slide left for taller, right for shorter. Do not know if it's in G9.
  • The base Genesis 9 has a set of Proportion controls that should handle this
  • MelanieLMelanieL Posts: 7,867
    The cheapest way to get to exact heights would be to create a simple plane in the scene then raise it on the y-axis to the exact height you want a character to be. Then making sure your figure has feet flat on the floor at 0 on the y-axis you could adjust the morph sliders until the top of the head exactly reaches the plane.
  • Thanks for the tips guys! I will be trying the cheapest way for now hahaha.
