Can't load material on Mystique 2
Keiku
When trying to load materials on Mystique 2, I get an error "An error occured while reading the file, see the log file for more details". Appears to affect any of the items. I have the items and surfaces selected.
LOG:
2022-10-24 11:59:28.948 [INFO] :: Error loading asset: E:/3D Artwork/!Daz Library/People/Genesis 8 Female/Clothing/Fantasy/Outfits-Sets/Mystique 2/Materials/M2 Pantyhose 1L Taupe Lace Pattern Nylons.duf
2022-10-24 11:59:28.948 [INFO] :: Operation failed
2022-10-24 11:59:29.018 [INFO] :: Unlocking viewport redraw...
2022-10-24 11:59:29.018 [INFO] :: Viewport redraw unlocked.
2022-10-24 12:01:51.304 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Clothing/Fantasy/Outfits-Sets/Mystique 2/Materials/M2 Pantyhose 1L Taupe Lace Pattern Nylons.duf
2022-10-24 12:01:51.304 [INFO] :: Locking viewport redraw...
2022-10-24 12:01:51.304 [INFO] :: Viewport redraw locked.
2022-10-24 12:01:51.407 [INFO] :: Native format content directories: 1
2022-10-24 12:01:51.407 [INFO] :: Poser format content directories: 1
2022-10-24 12:01:51.407 [INFO] :: Other import format content directories: 0
2022-10-24 12:01:51.407 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Clothing/Fantasy/Outfits-Sets/Mystique 2/Materials/M2 Pantyhose 1L Taupe Lace Pattern Nylons.duf
2022-10-24 12:01:51.418 [INFO] :: Determining missing assets...
2022-10-24 12:01:51.441 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2022-10-24 12:01:51.441 [INFO] :: Error loading asset: E:/3D Artwork/!Daz Library/People/Genesis 8 Female/Clothing/Fantasy/Outfits-Sets/Mystique 2/Materials/M2 Pantyhose 1L Taupe Lace Pattern Nylons.duf
2022-10-24 12:01:51.441 [INFO] :: Operation failed
2022-10-24 12:01:51.512 [INFO] :: Unlocking viewport redraw...
It's a hierarchical preset, presumably you are not using it on Genesis 8 or have overridden the default setting to parent fitted items. if you are using it on Genesis 9 try loading Genesis 8 Female and parent the items to that figure (leave them fitted to 9) - the preset should then work.
Huh. Strange. That was indeed the issue as I was trying to use it on Genesis 9.
