"new"desktop i'm putting together for DS 4.8 use - opinions pls
IkyotoIkyoto Posts: 1,159
4 GB DDR3 SDRAM RAM - 500 GB HDD - extra 250gb ssd - NVIDIA GeForce GT 610 - 1 GB - Windows 8.1 64-bit - 30" hd flat and 19" hd flat monitors.
I just needed a second machine. Backlogged like mad.
    would suggest 16gb ram if you could manage it.
    i'm currently at 4gb, lotsa a page swapping. >.<
  • EsemwyEsemwy Posts: 578
    Concur on the memory. Backup drive?
    Remember, hard drives are cheap; time is expensive and you can never get it back.
  • IkyotoIkyoto Posts: 1,159
    edited July 2015
    I've got the 250gb, am putting in a dvd  burner, a stack of other older hds and I can crank the board up tp 8gb. Next week is the install for all the daz stuff from here, rosity and rotica. I hope to have all of the stuff I use installed by thanksgiving.
    Post edited by Ikyoto on
    and organizing it so yoo can find it again laugh
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Also bear in mind that that video card will not do much for Iray, if you want to render with it. A 4GB 740, if it will fit your budget, would be better.
  • mtl1mtl1 Posts: 1,508
    I'd suggest a 960 4GB, but I'm kind of biased because that's what I'm using right now :D
    edited July 2015
    I acually have a notebook listing stuff I use alot by scene/genre. good old paper and pen. Othewise I'd be SO much more confuselled than usual.
    edited July 2015
     Both very good and vakid points, But I'm an old, cheap grump.
    @Ikyoto
    Still and all, you haven't even mentioned the processor. What attributes of 3d are important to you? If you are considering Iray, a (much) better video card will do more for you than the second monitor. Your specs imply a low end general purpose, e.g. Budgets, internet, email home computer rather than a machine intended for 3D rendering.
  • Testing6790Testing6790 Posts: 1,091
    Based on your build, I would recommend maybe losing a monitor to get more RAM. You won't really see much performance on IRAY with that card. What processor are you looking at? You're probably going to get some slow renders.
  • BendinggrassBendinggrass Posts: 1,388
    I would go for a Xeon processor with a decent number of cores, say 10 cores. Forget the SDD, and the small monitor and get as much RAM as possible. 2 X 1T HDD easily for back up..... just thinking.....
