Copy morphs to the new geometry.
va-silyva-sily Posts: 52
edited July 2015 in New Users
I created a new geometry of one to one with the original. Can I copy the original morphs from the original geometry to (on) my new geometry?
Post edited by va-sily on
  • Richard HaseltineRichard Haseltine Posts: 111,852
    What do you mean? If it's vertex identical, the way Genesis 2 Male and Genesis 2 Female are, then yes - either via OBJ (in which case the two moprhed figures will be indentical) or by copying the morph assets files across and doing minor edits - theer should be some discussions on doing this with G2M/G2F. Do bear in mind that if your starting mesh was not your own work you may not distribute the new figure.
  • va-silyva-sily Posts: 52
    I have my own a starting mesh with morph , such as women's panties slit on the genitals for Gen2F. slit is controlled with morph, I want to do the same panties for G3F and copy morph panties G2F to G3F,  is possible to do?
    It should be possible, yes, if it's the same basic model on both.
    Yes, that's one basic model of both. how to copy. write the path of action
    can anyone help me with this question?
    Sorry, I did a search and couldn't find the discussion I recalled.
    Thank you for your attention to my question. I'm still waiting for an answer.
  • larsmidnattlarsmidnatt Posts: 4,511
    edited August 2015
    You can transfer morphs with the transfer ultility. Even if the objects aren't an exact match. However the more they deviate in shape, the less likely it will work. Are you trying to transfer morphs from one set of panties to another set?
    Seems like you want to transfer morphs from a pair of G2F panties, to G3F panties. I think the best way to do this would be to dial in the Hidden G2F shape for G3F. Have G3F wear her panties.
    Load up the G2F panties. DO NOT FIT THEM TO ANYTHING. Be sure they are in default state. wait..i just wrote tutorial on this let me see if i can find.
    Instructions edited to fit your needs.
    1. Fit G3F panties to G3F.
    2. Dial in Hidden G2F shape for G3F. (see attachment)
    3. Load the G2F panties to scene.
    4. Launch the transfer utility. Its the icon that looks like a circle with an arrow flying out of it into a hollow circle.
    5. The important settings are Source = G2F Panties, Target = G3F Panties. In the transfer options do not fit the panties to the source(this would fit the G3F panties to the G2F panties which I don't want).
    6. You can transfer over morphs(highlighted in screenshot).
    Granted I have not tried doing this exactly this way...so there is one step that may need to change to make this perfect. Sadly I can't test at this time but if you run into issues I have a step that could change to make sure things work.
    587 x 239 - 33K
    300 x 214 - 25K
    485 x 573 - 57K
    Post edited by larsmidnatt on
    Thank you!
