Saving an expression with custom limits (Or a pose to turn off all limits)
Xameva
Hi!
I'm creating expressions for V7, but I find the limits of the expressions are too restrictive. I can manually edit the limits of each dial, but when I save the expression (for example brow Up-Down to +2) and re-load it on another V7 later, it retains the limits and goes to +1 only.
I wish to distribute these expressions... so I'm looking for a way to remove the limits within the pose file, or a single pose file which unlocks all the limits that can be loaded before loading the expressions.. I'm a Poser user, and in Poser you could simply text edit the .pz2 with "min and max" values. I've opened the DAZ pose file for an expression I saved and it's like:
"url" : "name://@selection#eCTRLBrowSqueeze:?value/value",
"keys" : [ [ 0, 0 ] ]
I tried adding "min" and "max" and "limits", but no luck. Does anyone know the line of code to set the limits? Or if there's a script to unlock all the expressions that'd be even better.
Thanks a lot. :)
I figured it out. Instead of using the one Up-Down dial, I needed to unlock and dial in the separate Right and Left dials instead and only dialing in those. Good practice anyway to not get symmetrical expressions.
Problem solved!
