Serial numbers disappear and other weird happenings
wsgentry
After upgrading DAZ 4.21. My DAZ serial number disappered. So did my Face Transfer license. I reloaded from DAZ, all good. Now the really strange thing.
I saved a pose from a different scene and applied the pose to the current scene, G8F to G8F. When I did that:
1. Hair color changed -- went to unsimulated state, too.
2. Removed third party products from the figure--readding did not fix the issue.
3. All instances of using the character the pose was applied to--in different scenes, subsets, etc., now exhibit 1 and 2,- above--even from backups!
Is there a way to clear whatever happened to the character--it is a Genesis 8 female generated with Face Transfer?
It appears the third party products while there, no longer work. They all worked until I applied the pose!
This happened suddenly! That affects the same character in different scenes is very odd! I've saved multiple poses and not had this happen before.
Thank you in advance.
I found a workaround for the pose issue... all used third party products needed to be applied to the source of the saved pose preset. Once I applied all the third party presets, it fixed the issue. What I don't understand is this: How can this affect the same character in different scenes?
Still there... work around worked until I saved the posed figure and tried to load it into a scene.
How do I get rid of the properties which seemed to transfer from the pose preset to the character I posed?
It's not fixed but saving the original image with the third party products seems to work.
