"Follow setting" ?
Scavenger
in The Commons
In a number of threads where I've expressed dificulty with some item (clothes, hair) will "spring back" in some weird despite how I move a part (like trying to straiten out a divot), I've seen comments regarding a "follow setting" like, "check what it's set to follow".
I can't find such a setting. Did I misunderstand?
On the item in question, if you right-click, there would be an option to "fit to" ... whatever is assigned there is what it is following. Sometimes it is best to set that to "none" and manually make the desired adjustments then just "parent" the hair [for eg] to the head [or whatever]. If I recall correctly said option may also be over on the parameter tab somewhere but I use the one in the scene.
oh, so "fit to" = "follow" ?
