What needs to be disabled or moved in draw style so the yellow shapes do not appear on mouse overs?
couldnt find that thread for this
thanks
  • Highlight style - set it to Bounding Box Only
  • marblemarble Posts: 7,500
    edited October 2022
    Just in case Richard's tip wasn't enough to help you find it ... It is a Draw Style setting as shown in this screen shot. I just tone down the highlights instead of removing them because they can be helpful.
    684 x 711 - 81K
    Post edited by marble on
  • VicSVicS Posts: 1,273
    thanks guys
  • jbowlerjbowler Posts: 867
    You can also turn the selectability of the yellow items off.  This is done in the Scene tab by clicking on the weird arrow+checkmark so that the check mark (tick sign) by the arrow becomes a cross.  ctrl-click to disable selection of everything.  This has the advantage that you do now get a yellow highlight for the things you might accidentally select otherwise.
    It took me years to work this out, but now whenever I am plagued by the yellow fungus I simply make the wall behind the objects unselectable.  In fact most of the time I make the whole building unselectable.
    jbowler is that different from locking the item?  will not turn yellow and will not be able to be selected
